Bob5545
Jul 14, 2021Aspirant
Extending 2.4Ghz devices to the extender, using 5.0 GHz network extender to router!
How do I do this? I want to have two extender networks, 5.0, and 2.4 that I have created.
However, I only want to connect from the extender to the router on the 5.0GHz network. So when I choose a device that only supports 2.4 GHz it will connect to the extender, and the extender will connect to the router 5.0GHz. I only want one network the 5.0GHz network active connected from the extender to the router. Can you do this?
The problem is when I connect my 2.4 GHz device to the extender, the extender connects to the 2.4GHz network on the router.
I want to use faster 5.0 GHz speeds from the extender to the router for 2.4GHz devices.
I want both 2.4, and 5.0 devices always using the 5.0 extender to router network.
Comments?
1 Reply
so shut off the 2.4ghz on the router.
Or change the ssid names and forget the ssid of the routers 2.4ghz from the devices you want on the 2.4ghz/extender network
