crbtree
Nov 21, 2022Aspirant
extending wifi into my garage
I have an rp7900 nighthawk router for my house. My garage is a steel building that blocks all signals. It is over 100 feet from the house, but I do have 200 feet of CAT6 ethernet cable I can run to t...
crbtree
Hello, I forgot to mention that I am using a CM700 cable modem into the RP7900. I do not know what an AP system is? I folllowed the link in your answer and it appears I can enter AP mode in settings of the router and then use the same setup in another router in the garage? My concern is that in step 6 my router loses connection with my computer? That is not what I want, I want my computer, currently hardwired into the router to maintain service, just add my garage.
Thanks again
Nov 21, 2022Guru - Experienced User
https://kb.netgear.com/000061927/What-is-the-difference-between-router-mode-and-AP-mode
I followed the link in your answer and it appears I can enter AP mode in settings of the router and then use the same setup in another router in the garage? My concern is that in step 6 my router loses connection with my computer? That is not what I want, I want my computer, currently hardwired into the router to maintain service, just add my garage.
Yes when your setting up the 2ndary AP in the garage, it will temporarily loose connect as the 2nd router has to reboot to configure the new AP configuration. The loss is only for about 1 minute or less. This is normal event when this happens.
