mcurtin201
Feb 04, 2021Aspirant
Extending wifi range with R6900
I am trying to extend my wifi range with the R6900. I have my DSP router wich is an Arris DG1670 I will use as the base and the R6900 as the extender. Ive never done thisand have tried but have not h...
mcurtin201
interesting. so use the 1670 to get the signal into the house then hard wire the 6900 to it and use that. So that in effect should extend my range more than what i have at present.
Feb 04, 2021Guru - Experienced User
I was looking through the dg1670's manual and couldn't find a modem only mode.
what you'd want to do then is connect the R6900 to the DG1670 and place the R6900 in access point mode.
This prevents a double nat.
https://kb.netgear.com/30186/What-is-Double-NAT
A double nat is when 2 routers are running on the same network with both in router mode.
you'll still be able to use the R6900's wireless/ethernet but you lose some advanced features like qos, traffic monitoring, etc.
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
- antinodeFeb 04, 2021Guru
> only mode.The (information-free) "Touchstone(R) DG1670 Data Gateway User's
Guide"? I know nothing, but my quick Web search for:
Arris DG1670 modem only
found:https://www.nextiva.com/support/articles/arris-dg1670a-modem.html
which suggested: LAN Setup > NAT Mode : Bridged
But what do I know?
- plemansFeb 05, 2021Guru - Experienced User
antinode wrote:> I was looking through the dg1670's manual and couldn't find a modem
But what do I know?
Thanks! You found a different manual than I did. Appreciate it!
- mcurtin201Feb 04, 2021Aspirant
Ok thanks for all this info. I'll give it a shot. I'm sure that I'll be back with more questions.
