OnesQuared
Oct 29, 2017Guide
Extensively High ping on wow with R7000
My brother recently purchased the R7000 model and after the switch, my WoW ping has been unnatrually high, fluctuating from 12k to 22k. The firmware was updated earlier today as of ( oct 29/2017)...
- Oct 31, 2017
I solved the issue, atleast for WoW, you just turn off ipv6 from the system-> network
William10a
Oct 29, 2017Master
Is your qos turned on or off ?
OnesQuared
Oct 29, 2017Guide
its turned off
- William10aOct 29, 2017Master
What was your like before the new netgear was install was it a standard modem to router to computer network?
Did the new netgear replace another router or did you just added the netgear after the your old router?
- OnesQuaredOct 30, 2017Guide
I had no issue without the netgear, I was running standard modem+router the isp provided previously.
The netgear was added to the modem, before we were just using the modem
