Stuart_C
Sep 03, 2021Aspirant
External antenna power rating
Hello all, What RF power rating is the MR1100 rated at. I am wanting too use a external antenna rated at 10watts. Is this OK or will it damage the Router or antenna. Regards Stu
michaelkenward
Sep 04, 2021Guru - Experienced User
As the label says, the MR1100 is a Mobile Router. You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Mobile Routers, Hotspots & Modems
Those things are very different from the standard Netgear Nighthawk routers covered in this section. I doubt if many people familiar with the MR1100 hang around here.
I will ask the Netgear moderator to move your message.
Stuart_C
Sep 04, 2021Aspirant
Thank you
