Syphil24
Oct 22, 2021Follower
External antenna with Nighthawk MR2
Hi, I have purchased a Nighthawk MR2 4G Router for use in may Motorhome. It works well, but I want to improve reception in zones of poor signal with an external antenna. the antenna will be fitted o...
Oct 23, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the NG Smart Router products. Most of the people who watch that forum are more likely to have experience with general routers and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/General-WiFi-Routers-Non/bd-p/home-wifi-routers-general
Thank you
