Xant0's avatar
Xant0
External Drive Testing CHKDSK
I have a Nighthawk X6 R8000 and I love it. It has the latest FW, V1.0.4.28_10.1.54, which I noticed that a few people are having issues but I seem to be the lucky one, that or I got a Canadian version.
I have 2 drives connected to the router. 1 LACIE 1TB external drive and 1 Seagate 5TB drive which I use both all the time. Now lately I have to recycle the router and/or external drives as they seem to go missing. now is there a way to test these drives, the Seagate 5TB in particular while plugged into the router?
Ok now security. Am I able to setup folders through the router with l/p's just like a NAS or a Windows Pro? If so how? As I have tried everything and stil everyone has access to the 2 drives. It also says "Warning: We strongly recommend that you enable Admin Password Protection to secure your ReadySHARE data. If you did not change the default admin password, we also recommend that you change it to secure your network." which I've done and as soon as I do it the shares turn red X and if I double click the shared drive I expect for it to ask me for the l/p but it doesnt do that. I've created a bat file "net use" with all the info to run on startup or double click and still no go.
And is there a way to change the "timeout" on the router lol? :)
I am a newbie here so please be gentle and I thank you all HUGE.
JAS
  • Hi JAS
    Xant0 wrote:
    ..., that or I got a Canadian version.
    I can't think there is anything the like - what says the label on the back for the model number, something like R8000-100xxx ?
    Many different cause are possible.
    The Nighthawk routers don't offer any file system integrity checking.
    With the HDD not detected and mounted (why ever) doing it would be even harder.
    Eject/unplug and run a file system check e.g. on your Windows system.
    Hi JAS
    Something like a net use /delete would make the Windows system forget any mapped shared folders.
    The Nighthawk routers only support using the admin account and your configured password - that's the only username/password we can apply on the external storage devices resp. the configured shared folders.
    When mapping the shared folders - ideally by browsing from Windows Explorer using \\readyhsare\ or \\192.168.1.1\  and clicking on the shared folder(s) configured, the system should ask you for the (admin) username and password.
    The Web UI timeout? I don't think so...
  • You have me confused somewhat?
    Screen Capture, is that a composit one? The top what the Router READYSHARE page partially have and the bottom from a MAC?
    I assume you are on a MAC? I have no real experience with a MAC, using Windows 10. I have no problem with one or two USB drives connected to my R8000?
    I have NEVER seen this message, "Warning: We strongly recommend that you enable Admin Password Protection to secure your ReadySHARE data."? Where are you seeing this?
    Did you change anything on the router and had them start going missing?
    There is no way to test a Network drive on Windows that I am aware of? When I suspect a drive problem I bring it to a PC and run CHKDSK on it.
    I do have a drive sub-folder password protected. In order to use that I had to create a Windows Credential to access it. I only protected with a password a single folder that I would only access from my specific PC. Can't protect the whole drive. Too many programs will NOT see the drive as they have no capability to handle a login request. Specifically any and all DLNA Clients I use on Smart TV's, iPad's, and phones.
    BTW, you are only the 2nd person that has posted here that said they had a 5TB drive working on the router. All others are 4TB or smaller. Nothing higher either.
    What is the BAT/CMD file contents? Does it include the router UID and PW? Might need to look like this, net use s: \\192.168.1.1\drive1 /user:myDomain\myUser myPassword?
    • Xant0's avatar
      Xant0
      OK sorry about the confusion as I am sick and was tired, still am. I am unsure what you mean by "Composit"? as the screen shot was 3 clipped with snipping tool in Windows 7 x64 Pro and then I couldn't attach 3 pix I put them all together in Photoshop. Attached is the full page Under Advanced > ReadySHARE Storage > USB Storage (Advanced Settings).
      The message "Warning: We strongly recommend that you enable Admin Password Protection to secure your ReadySHARE data. If you did not change the default admin password, we also recommend that you change it to secure your network." has been there since the very first day I bought the router, Nighthawk X6 R8000, here in Canada. Maybe being here in Canada has something to do with different settings? As for being on a MAC, nope, good old Windows 7 Pro x64. You will see that warning in the screen snip I attached. Is there a way to attach for then one file to this discussion?
      So if I Enable the, Network Neighborhood/MacShare \\readyshare, everyone in the house will be able to see it and have full access to it. It's interesting because until now, or when you said, I never noticed MacShare the name. Maybe thats the whole issue right there. No I haven't changed anything on the router other then FW updates regularly when they are ok.  I did the command "C:\Windows\system32>net use s: \\Readyshare\5tb The command completed successfully." now I have a drive S: and a drize Z: showing up in my "Network Locations" and I can access both from prompt but router shows ONLY the one share.
      Yes I figured there wasn't a way to test it through the router I just figured I'd ask as in older NAS's theres an option to test but I know this is not a NAS :) I am stil stumped about the "MacShare" and I can't remember if I created the folder directly in the drive or I did it through the router dashboard. Apparently I am going to have to do a bit of reading or blow everythng away and start over.
      I see your response "I do have a drive sub-folder password protected. In order to use that I had to create a Windows Credential to access it. I only protected with a password a single folder that I would only access from my specific PC." and was wondering how you do this? I create a subfolder in the drive "\\192.168.1.1\5tb\_Personal" and if I go to security it shows Users: Everyone, nobody (Unix User\Nobody) and Root (Unix Group\root) but there are no permissions on any of the 3, so I am assuming it's because it's in the MS settings and not UNIX. So in this case how do you lock it down to a single user? Thanx for the info regarding unable to protect
      • Xant0's avatar
        Xant0
        I missed this one, plus. First off I wanna make sure that everyone knows the 2 external drives are working perfect but it appears that maybe some of you all thought the drives weren't workings. I was told that the I was the second person to post here that they had a 5TB drive working on this Router Successfully. Since July 2016 it's been going steady. As for the "BAT/CMD file contents" I have NO clue what these are or where to get them. :) Thanx again all for the help.
  • schumaku's avatar
    schumaku
    Hi JAS
    Hi JAS
