Mrljd05
Nov 16, 2023Aspirant
External Hard Drive with Nighthawk R7000p
I have a Nighthawk R7000p router that I have had for at least four years. I bought a Seagate Portable 5TB External Hard Drive HDD (model STGX5000400) to use as central storage. I am unsure how to get...
Mrljd05
Dec 20, 2023Aspirant
Hi, I have plugged the seagate hard drive into the Netgear Nighthawk router. However, when I view the Nighthawk app, there is no option to view files on a network. I have the legacy Netgear Genie app that allows to me to see the media files on the external hard drive, but that app is outdated and it does not allow for the management of my router through it. I can only do that through the Nighthawk App. Its nice that I can see the files, but I was hoping to be able to easily add files over my Wifi network.
michaelkenward
Dec 20, 2023Guru - Experienced User
My 8TB Seagate works just fine.
The Nighthawk App isn't the right place to look for network access. It can't see ReadySHARE. That is designed for your local network. Windows does that.
\\Readyshare
You need to go in with a web browser and the graphical user interface (GUI).
Did you read my first response?
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual Share USB Storage Devices Attached to
the Router
Which app is that? The mobile or desktop?
By media files, are you using the router's DLNA server?
