KenDRider
Feb 24, 2018Aspirant
Extremely slow 2.4 GHz network
I was out of town and one of my security cameras reported it was offline and another was online but barely streaming. When I got home I noticed all of my Wifi connected devices were extremely slow. I...
- Jun 12, 2018
Hi All,
A new firmware update is available. Please update the firmware to 1.0.9.32
https://kb.netgear.com/000059134/R7000-Firmware-Version-1-0-9-32
Blanca
Community Team
michaelkenward
Feb 25, 2018Guru - Experienced User
Which firmware version do you have on the R7000? Do you have any Chromecast/Android devices around?
There has been a flurry of activity on that front recently.
R7000 keeps losing 2.4GHz wireless connectivity - NETGEAR Communities
- profeta64May 19, 2018Luminary
Hi to all, I am in the same situation, with the latest beta firmware: V1.0.9.30_10.2.33.
I have three Android phones connected, and with my Samsung S7 I cannot exceed the 8mbps (average is 5mbps) even if it is close to the router.
I tryed several channels, but does not make any differences.
- michaelkenwardMay 19, 2018Guru - Experienced User
More a hotfix than beta firmware:
R7000 Firmware Version 1.0.9.30 - Hot Fix | Answer | NETGEAR Support
Did you reset the router to factory settings after the firmware flash?
New firmware sometimes introduces changes that are not compatible with the old configuration.
So while it isn't guaranteed to fix problems a factory reset is the first thing to try if you have issues with new firmware.
This is a nuisance because you then have to reconfigure the device all over again.
You can backup your settings before you reset and restore them later. But that may just bring back the fault. Then again, at least you will know if the reset fixed the problem.- profeta64May 19, 2018Luminary
So, currently I installed this update, coming back from DD-WRT.
The main reason why I left the original software was the issue with openVPN, which has been corrected on this beta/hot fix version.
I made the current configuration of the router from scratch, after to have performed the 30-30-30 reset procedure.
I think then that if I will reset again the router, and restoring the configuration will not make any differences.
Isn't it?
