KenDRider
Feb 24, 2018Aspirant
Extremely slow 2.4 GHz network
I was out of town and one of my security cameras reported it was offline and another was online but barely streaming. When I got home I noticed all of my Wifi connected devices were extremely slow. I...
- Jun 12, 2018
Hi All,
A new firmware update is available. Please update the firmware to 1.0.9.32
https://kb.netgear.com/000059134/R7000-Firmware-Version-1-0-9-32
Blanca
Community Team
profeta64
May 19, 2018Luminary
So, currently I installed this update, coming back from DD-WRT.
The main reason why I left the original software was the issue with openVPN, which has been corrected on this beta/hot fix version.
I made the current configuration of the router from scratch, after to have performed the 30-30-30 reset procedure.
I think then that if I will reset again the router, and restoring the configuration will not make any differences.
Isn't it?
michaelkenward
May 19, 2018Guru - Experienced User
Restoring the configuration may also restore the bugs that you saw before the reset.
Try it. If the same pre-update problem exists reset and then do not restore.
- profeta64May 21, 2018Luminary
So, I choosed to use the previous V1.0.9.28 firmware, applied directly over the V1.0.9.30.
Now I got full speed :smileyhappy: -> speedtest.net at 32mbps as my line
The drawback is that the VPN now it is not woorking... :|
- Blanca_OJun 12, 2018NETGEAR Employee Retired
Hi All,
Blanca
Community Team
