jziggy101
Sep 18, 2019Aspirant
Extremely SLOW 2.4ghz Wifi on R8300 but not on R6700v2
I recently took out of service my R6700v2 router and put in a new R8300 in its place. Everything seemd fine until my son complained that his wifi was slow.. I spent several hours checking his laptop out and all the drivers were the latest and other thatn 2.4ghz being very slow nothing else was wrong.
I then checked with my laptop on 2.4 and it was so slow on speedtest.net. If I tried 5ghz I would get speeds of over 111Mbps, my wired pc was getting over 125Mbps but the 2.4ghz was barely getting 1Mbps and more often less than that.
I shut my R8300 off and put the R6700v2 back into the network. After doing all the necessary checks to make sure the network was back up I did speed tests again.
2.4ghz = over 50Mbps on my son's laptop
2.4ghz = over 75Mbps on my laptop.
5ghz = over 118Mbps on my laptop
All these checks were done using the same local destination server. I did multiple tests to the same local server on all devices and the results were nearly the same.
I checked all the drivers on both laptops and everything was up to date.
I then put the R8300 back in the network and removed the R6700v2. All 5ghz speeds were nearly identical to the R6700 but the 2.4ghz speeds were in the toilet again. I have about 5 wifi enabled outlets in the house as well as a Google mini that are running on 2.4 but that did not change when I went from one router to another.
I can only assume the R8300 is the problem. I checked that the R8300 was at the most current firmware and it is.
I found a solution. I am returning the Nighthawk R8300 and looking at other products and possibly vendors to fit my needs.
1 Reply
- jziggy101Aspirant
