Elixir86
Nov 11, 2020Follower
Extremely slow router internet speeds when connected to Cisco Systems VPN Client 5.0.07.0440
Router - Netgear R6700v3 Firmware Version - V1.0.4.102_10.0.75 OS - Windows 7 Professional Edition Problem - Extremely slow router internet speeds when connected to Cisco Systems VPN Client 5.0.07...
Nov 11, 2020Guru - Experienced User
A VPN runs your connection through the host server. If your speeds are fine when not on a vpn but are slow while on it, you should be checking with the host server as its the bottleneck. If that's your work one, check with your work IT department.
