PrayJ
Jul 10, 2022Aspirant
Extremely slow speed r8300
Hi I am getting very slow speeds through my router. I have R8300 router and a CM1000 modem, using it with Xfinity Comcast. This issue started out of nowhere and without any input from me. Comcast ha...
michaelkenward
Jul 11, 2022Guru - Experienced User
PrayJ wrote:
Hi
Measured how? Measured where? Connected how? Wifi? Wired?
Direct connection to my laptop using an ethernet cable gives me a steady 900mbps+ speed.
From laptop to what? Modem? Router?
- plemansJul 11, 2022Guru - Experienced User
What actual speeds are you getting wired into the router?
When you reinstalled after the firmware update, you put you left qos off. did you also make sure to leave parental controls, access controls, and traffic monitoring off? If they were ever enabled, factory reset again and during the reinstall, leave those disabled.
Did you reinstall from a backup? If so, don't.
- PrayJJul 11, 2022Aspirant
Thanks plemans
There is no speed issues with a wire connection to the router - steady 900mbps speeds.
QOS, Parental Control, Access Control, Traffic Monitoring were never turned ON or enabled before or after the reinstall.
No reinstall from backup. This was a fresh reset to factory settings. The only things that are the same are the SSID ID and passwords. I did not change those as I have many smart devices connected to it.
Thanks.
do you have ipv6 enabled?
Try enabling that.
If it doesn't help, try downgrading the firmware a version.
Thanks for replying michaelkenward
Measured:
1.Using ethernet cable connected directly to a laptop and a desktop.
2. Wirelessly with a cell phone, tablet and a laptop in close proximity to the router.
Internet connection is through the modem (CM1000) to the router and from the router to the device using ethernet cable.
I have changed the cables to rule out faulty equipment.
This same setup was working perfectly fine for a number of years. 900mbps+ speeds through ethernet connection. 500mbps+ wirelessly. Now it is crawling at barely 2mbps. Ethernet connection to the laptop through the router is perfect - steady 900mbps.
Thanks.
