PrayJ
Jul 10, 2022Aspirant
Extremely slow speed r8300
Hi I am getting very slow speeds through my router. I have R8300 router and a CM1000 modem, using it with Xfinity Comcast. This issue started out of nowhere and without any input from me. Comcast ha...
michaelkenward
Jul 11, 2022Guru - Experienced User
PrayJ wrote:
Hi
Measured how? Measured where? Connected how? Wifi? Wired?
Direct connection to my laptop using an ethernet cable gives me a steady 900mbps+ speed.
From laptop to what? Modem? Router?
PrayJ
Jul 11, 2022Aspirant
Thanks for replying michaelkenward
Measured:
1.Using ethernet cable connected directly to a laptop and a desktop.
2. Wirelessly with a cell phone, tablet and a laptop in close proximity to the router.
Internet connection is through the modem (CM1000) to the router and from the router to the device using ethernet cable.
I have changed the cables to rule out faulty equipment.
This same setup was working perfectly fine for a number of years. 900mbps+ speeds through ethernet connection. 500mbps+ wirelessly. Now it is crawling at barely 2mbps. Ethernet connection to the laptop through the router is perfect - steady 900mbps.
Thanks.
