laurenhawk
Nov 23, 2021Follower
Facing problem with Nighthawk R7000 AC1900
Hello, all I have a new Nighthawk router it is performing well however, my Iphone does not show up in the attached devices. I have tried all possible things I can do but no luck the device is not showing up. Anyone else facing similar problem? and how you fixed the issue...
1 Reply
What firmware is on the R7000?
Does the Iphone connect to the wifi?
Where are you looking for "attached devices"?
