MJMurry
Sep 28, 2018Aspirant
Factory Name vs mine
I purchased and set up my router and wifi. I renamed my network and set a passcode separate from the factory sticker on the actual router. Now I see the factory name showing up in my computer toolb...
- Sep 29, 2018
MJMurry wrote:
the netgear95 was factory set. Int he system tray it shows up as netgear95 ...
Please read my message and see if you can follow the instructions.
You can keep on restating you problem, but unless you follow the advice that people give you, we are going to get nowhere near to solving the problem.
If you cannot understand the messages from other people, tell us which bits baffle you. No matter how hard some of us try, it isn't always easy to put yourself into another user's shoes. You never know how familiar they are with this stuff.
Maybe this will also help:
How do I change the name on my Nighthawk router? | Answer | NETGEAR Support
It has the advantage of a picture of the relevant screen.
antinode
Sep 28, 2018Guru
> [...] I renamed my network [...]
What, exactly, did you rename? An R7000 has two wireless network
names (SSIDs), one for the 2.4GHz radio, one for the 5GHz radio. If you
change the name (SSID) of only one, then you can expect to see both your
changed name and the default name (on devices which can use both radio
bands).
> [...] Now I see the factory name showing up in my computer toolbar.
What, exactly, do you see?
Visit http://netgear.com/support , put in your (actual) model number,
and look for Documentation. Get the User Manual. Read. Look for
"Specify Basic WiFi Settings".
MJMurry
On the app, both my settings have the network SSID (Wifi band) name I chose for both 2.4 and 5G. When I hover over the intern access icon in the tool bar next to the clock on my computer, it states NETGEAR95 (which is the name on the router used to log in originally). Once I restart the rcomputer, it shows up as my network name I chose
