MJMurry
Sep 28, 2018Aspirant
Factory Name vs mine
I purchased and set up my router and wifi. I renamed my network and set a passcode separate from the factory sticker on the actual router. Now I see the factory name showing up in my computer toolb...
- Sep 29, 2018
MJMurry wrote:
the netgear95 was factory set. Int he system tray it shows up as netgear95 ...
Please read my message and see if you can follow the instructions.
You can keep on restating you problem, but unless you follow the advice that people give you, we are going to get nowhere near to solving the problem.
If you cannot understand the messages from other people, tell us which bits baffle you. No matter how hard some of us try, it isn't always easy to put yourself into another user's shoes. You never know how familiar they are with this stuff.
Maybe this will also help:
How do I change the name on my Nighthawk router? | Answer | NETGEAR Support
It has the advantage of a picture of the relevant screen.
MJMurry
Sep 29, 2018Aspirant
The SSID names for both the 2.5 and 5 signals are both changed and verfied and confirmed in the netgear app set up. My computer wireless adpater only functions on the 2.4 ghz signal. the netgear95 was factory set. Int he system tray it shows up as netgear95 and then when i clockon that to show networks it shows i am connected to the SSID I named. If I restart my computer or reconenct to my named conenction it shows up as such in the system tray
michaelkenward
Sep 29, 2018Guru - Experienced User
