Mkmemre
May 02, 2023Follower
Factory Reset AC 1750 Model R6700V2 Can't Seem to Factory Reset
Hi Power Users and knowing Nighthawk WIFI users. I have a AC1750 Smart WIFI Router, Model R6700v2. I use it as stand alone, and want to use it as an access point to extend range within house. I...
microchip8
May 02, 2023Master
Factory reset wipes out all custom settings you have done, including passwords, and reverts them to defaults
Try with a browser to go to http://routerlogin.net or http://192.168.1.1 and use "admin" as user and "password" as pass to login. You can then set up AP mode and WiFi passwords
michaelkenward
May 05, 2023Guru - Experienced User
Do that, and then read this:
How do I change my NETGEAR router to AP mode? | Answer | NETGEAR Support
