ganon0's avatar
ganon0
Tutor
Mar 07, 2016
Factory reset doesn't work
I have a Nighthawk X8 I bought two months ago. Up until today (Mar 7), it has been running fine. Today I came home and found it wasn't working. I tried to access it via routerlogin.net, nothing worked. I've tried to factory reset using a toothpick about 5 times now, but it doesn't seem to matter; my computer (hooked via ethernet) doesn't allow me to configure it, and I can't see it wirelessly. The power button stays amber most of the time but it seems to reset itself every once in a while.
I tried calling customer support, but they hung up on me while beginning to register my router midsentence. I'm afraid I'll need an RMA, unless someone can tell me why factory reset isn't working. I've tried doing it for 8 seconds (directions say that), longer, multiple times, while it was on, off, both, etc. None of it helps.
If I can't get the factory reset to work, is there a way to set up an RMA without calling? After the initial CS hangup, I was told I'd be on the phone for an hour waiting for help.
  • ganon0's avatar
    ganon0
    Mar 16, 2016
    I ended up doing an RMA. Got my new unit and it's working fine right now. Hopefully it won't quit in 2 months like the last one...
  • Seea ny lights on the router is unusual? Tried to ping the router? Push and hold down the reset button for couple mins.
    and let go. Can you see router rebooting? Your wall wart may be bad.
    • ganon0's avatar
      ganon0
      Tutor
      How many minutes do I hold it? Should the router be off when I do it? Do I turn it on while holding the reset button? Off and on throughout? What lights do I watch (front vs top vs antennae)?
      • VE6CGX's avatar
        VE6CGX
        Master
        Try again, turn off the router. Push and hold down the reset button and turn the router on. Wait until power light blinks
        and let go. What happens then?  If you have spare wall wart try that too.
  • I have the same router and have been having the exact same issue for 2 days now.
    • ganon0's avatar
      ganon0
      Tutor
      • NightOwl326's avatar
        NightOwl326
        Luminary
        Everything has a defect rate be it a Netgear router or a toaster. You will be fine.
