MJC314
Oct 03, 2021Follower
Factory reset issues RAX43
Can't seem to get the factory reset done correctly. I have the app and when I choose the WiFi, it asked for the password and I continue to get "incorrect password" message. Help!
1 Reply
Have you tried hardwiring a pc/laptop into it?
Then you can go through setup and check/change the wireless ssid/password and it skips having to know them for setup.
