PointyHorns's avatar
PointyHorns
Factory reset nighthawk r8000 now there’s no internet
I was having very slow internet speeds on my (wired) PC when I set up my router at my new apartment. I have fiber Gbps speeds. When I plug my PC directly into the ONT, it works perfectly so I was able...
  • PointyHorns's avatar
    Jun 23, 2021
    Nevermind, I am dumb. I did not realize you needed to use the app to set it up after factory reset as I have not set it up in a long time.
