khogawani
Sep 01, 2022Follower
Factory Reset Nighthawk Rx500 router, now no internet.
I factory reset my router (pin reset) and now I have no internet connection. The internet led is flashing white, every time I try to set up my router on routerlogin.net I get “400 bad request”
I have cleared my browser cache. Used different browsers. Tried the 30/30/30 method. I feel like I’ve done everything to no avail.
I am hoping someone can help me out.
What model router do you have? XR500?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.- michaelkenwardGuru - Experienced User
Specialist advice for that is here:
Nighthawk Pro Gaming Routers - NETGEAR Communities
Gaming routers have their own DumaOS operating system that is nothing like the one on Netgear's standard routers.
