Anonymous
Nov 02, 2021Factory Reset NOT WORKING!
I have Netgear R6260 AC1600 and I have reset the mode like 100 times, pressed the reset button for 5 seconds, for 30 seconds, for 1 minute and stupid modem will not reset the admin password. I canno...
Nov 02, 2021Guru - Experienced User
Netgear has set up a community forum specifically for General Router products. Most of the people who watch that forum are more likely to have experience with older routers and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/General-WiFi-Routers-Non/bd-p/home-wifi-routers-general
The R6260 is a router, NOT A MODEM! .
Pressing the Reset button for 10 seconds should work to reset the router.
Besure to clear out all browser caches. Try a different browser.
If not, try a 30-30-30 reset process.
Thank you
