raven403
Sep 04, 2023Follower
Factory reset on nighthawk and now slow upload speeds.
I have ATT and pay for the 1000 mbps. That speed test shows 999 upload/ download. It’s connected to a nighthawk that was having a issue showing I had a update it could not download. Spent 2 hours pla...
Kitsap
Sep 04, 2023Master
You might also find this useful:
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
Experienced Netgear users prefer the manual update method over the automatic process. If you do not have the hardware to connect to your router via Ethernet, a good Wi-Fi connection should work.
