prosportal
Mar 11, 2018Aspirant
Failure Connection (Honeywell WIFI Thermostat)
 I have had a Honeywell Wi-Fi Thermostat (RTH6580WF) for a number of years now. Within the past 6 months, I purchased a Nighthawk R6400. Since then, i always get "Connection Failure" on my thermostat;...
- Mar 13, 2018Try dropping 2.4 GHz mode mode from "450 Mbps" to something lower (changes from 40Mhz mode possible to 20Mhz mode)?
prosportal
Mar 14, 2018Aspirant
Official response:
Thank you for contacting Honeywell.
We sincerely regret the inconvenience caused.
Honeywell thermostats only operate on the 2.4GHz range meaning they are only compatible with wireless 802.11 b/g/n.
They are not compatible with the 5GHz networks, 802.11 n/ac. There is not a need for this compatibility since the thermostat is a low bandwidth device. Also, the 2.4GHz frequency gives a better distance and penetrating power vs the 5GHz range.
michaelkenward
Mar 14, 2018Guru - Experienced User
That doesn't help. Of course they do not support 5 GHz. They simply won't see it or try to connect.
What you need to know is any restrictions on the 2.4 GHz. That is what duckware is getting at.
