Marskat
Oct 11, 2018Tutor
fake_upd blocking with Norton Antivirus
I just updated my Netgear firmware and am now constanty seeing my Nortin Antivirus blocking someing called 'fake_upd'... anyone heard of this, what is it, and how do I make it go away?
- Oct 12, 2018
Big thank you to Antidode and Myersw for the suggestion to remove the NetGearGenie App from my Mac. That removed the probem. I will take your suggeston and use the NetGear website exclusively. I spent hours on the phone with NetGear - where they offered to have me pay $100 to remove the problem. When I saw your suggestion to remove the App, I did a head slap, then followed you advice... now I am problem free. Well done to you both!
antinode
Oct 11, 2018Guru
> Sorry for the typo - it does read Fake_UDP.
With or without the capital letters?
> [...] I don't know what the previous firmware was but the current
> firmware on the router is V2.4.38 [...]
That's not an R7000 firmware version. It might be something like a
Mac Genie app version number.
Apparently, the Mac Genie app (recent versions?) does something which
some anti-virus software doesn't like.
Unless I really needed some feature which only the Genie app
provides, I'd discard it, and stick with the web-browser interface.
myersw
Oct 12, 2018Master
I agree. The apps that are supposed to be helpful seem to cause more headaches then just pointing browser at the router's IP address which is usually 192,168.1.1. I personally have never found where I wished I had one of the Genie apps installed.
- schumakuOct 12, 2018Guru - Experienced User
Please query the Internet security **** vendors about _their_ messages - for an explanation, for a risk description, for a possible remediation. This message is not generated by Netgear, neither by the router or extender firmware nor by the Genie program/App.
- antinodeOct 12, 2018Guru
> [...] This message is not generated by Netgear, neither by the router
Well, duh. The _message_, whatever/whoever emits it, refers to an
_action_ by "NETGEARGenie.app", as seen in the cited thread. Why any
part of "NETGEARGenie.app" is trying to open a UDP connection to
"0.0.0.163:55" is a mystery to me, but I can see why some anti-virus
program might complain about it.
It's such nonsense that, personally, I'd be tempted to "Allow" "Only
0.0.0.163 and UDP port 55 (isi-gl)" just to shut it up, but I'd like to
see an explanation from Netgear of the purpose of this nonsense. - MarskatOct 12, 2018Tutor
