Marskat
Oct 11, 2018Tutor
fake_upd blocking with Norton Antivirus
I just updated my Netgear firmware and am now constanty seeing my Nortin Antivirus blocking someing called 'fake_upd'... anyone heard of this, what is it, and how do I make it go away?
- Oct 12, 2018
Big thank you to Antidode and Myersw for the suggestion to remove the NetGearGenie App from my Mac. That removed the probem. I will take your suggeston and use the NetGear website exclusively. I spent hours on the phone with NetGear - where they offered to have me pay $100 to remove the problem. When I saw your suggestion to remove the App, I did a head slap, then followed you advice... now I am problem free. Well done to you both!
antinode
Oct 12, 2018Guru
> [...] This message is not generated by Netgear, neither by the router
> or extender firmware nor by the Genie program/App.
Well, duh. The _message_, whatever/whoever emits it, refers to an
_action_ by "NETGEARGenie.app", as seen in the cited thread. Why any
part of "NETGEARGenie.app" is trying to open a UDP connection to
"0.0.0.163:55" is a mystery to me, but I can see why some anti-virus
program might complain about it.
It's such nonsense that, personally, I'd be tempted to "Allow" "Only
0.0.0.163 and UDP port 55 (isi-gl)" just to shut it up, but I'd like to
see an explanation from Netgear of the purpose of this nonsense.
Marskat
Oct 12, 2018Tutor
