JCGUTMN's avatar
JCGUTMN
Initiate
Feb 09, 2021
FASTLANE CONFIGURATION FOR AC2200 (EX7300)
Charter Communications/Sepctrum supplied Hitron Technology EN2251 modem with SAGECOM SAC2V2S router with both 2.4 and 5 GHz channels.  NetGear AC2200 (EX7300) WiFi Mesh Extenter.     FastLane config...
  • plemans's avatar
    Feb 10, 2021
    JCGUTMN wrote:
    Are the latency differences using 2.4 GHz versus 5 GHz in the range of 1ms, 10 ms, seconds?   To configure to use the 5GHz speed, set up with FastLane using 5 GHz to 5 GHz?    Its going to be different for everyone because of distance, interference, obstructions, etc. But if you're not doing any gaming, its not really an issue because it tends to be in the MS range not second range. So you wouldn't NEED to use fastlane. But you can always try it several different ways and see what works best.
