JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
JamesGL
Hi MPrinter17,
Can you disable the Smart connect first and observe the connection? We will try to identify if the those features being enabled affect the performance of the wireless.
MPrinter17
Dec 18, 2017Star
Done. I've disabled the Smart Connect and seperated my 5G and 2.4G devices to different SSID's. I'll let you know how it goes.
JamesGL wrote:Hi MPrinter17,
- brianhelmanDec 22, 2017Apprentice
I'm also experiencing the 2.4GHz drops. I upgraded to 1.0.9.18_x code with Smartconnect enabled. The problem did not go away. I disabled Smartconnect and separated the 2.4/5GHz SSID's. I've now been running with Smartconnect disabled for 4 or 5 days and the problem persists.
I have to reboot my router 2-3 times a day to get my 2.4GHz devices back on the network. I've moved any device that is 5GHz capable to my 5GHz SSID, but that doesn't help with all of my 2.4GHz-only devices (e.g Nest Protects).
This problem existed under the previous code release. I'm very disappointed that Netgear hasn't corrected the problem. If a solution doesn't get posted soon, I will need to try Advanced Tomato.
