JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
Netabc123
Dec 18, 2017Guide
Copied from the other thread:
I have rebooted, but not yet done a factory reset. I will do so later when there's less traffic on the network.
For me, the issue isn't device specific, rather it is band specific. When the 2.4GHz has issues, all my devices are unable to obtain an ip via the 2.4GHz network. Same thing happens randomly to the 5GHz network (different SSID). As far as I'm aware, the timing the of the issues occur randomly and can only be fixed with a reboot or applying a change to the router. There are times I can use both networks and times when it's one or the other. If I'm having issues with one, I can switch to the other on the same device and have it work fine.
Note: I've never had smart connect enabled
