JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
Laudek
Dec 18, 2017Star
Ok so updated to the current version of the firmware roughly 3.5 hours ago. All was fine with wired and wireless connections for a bit. First noticed the wireless connection to the HP 8710 printer dropped and while the system could identify it, it could not communicate with it. This was about 20 minutes ago. Also noticed my son's all in one HP Pavillion was showing internet access but could not connect. Also noticed the Nexus 6P dropped its connection but could recognize the WiFi. The wired connection to the PC was fine.
So.... attempted to login via the Genie app on the wired connection. No luck after 3 attempts. Logged in via Edge browser. Was able to disable Smart Connect. Logged off, and cycled off the router followed by:
the PCs both wired and WiFi (both running Windows 10 version 1709)
the cell
the printer.
Seem to have connection in all devices including the Nest and Google homes.
Attempted to router login via Edge and it routed me to password recovery. Was able to login via chrome and confirm connections as well including for Google home. Noted that two Google Homes were in 5Ghz and the third on the 2.5 band.
Will monitor. If I start dropping connections again tomorrow there are two steps left for me.
1) reset router to factory settings, update and restore settings and if that fails
2) flash back to version R7000-V1.0.9.12_1.2.23
Netabc123
Dec 18, 2017Guide
I've basically had the same experience as Laudek above. When one band is having issues (eg. 2.4GHz), I can see the 2.4GHz network, I can join it, but I get no ip and therefore no connection to the router (can't log in) and cant see any other device on the network. If the 2.4Ghz network is having issues, I can switch to the 5GHz network and access to the router, internet and any other device connected on the 5GHz network. The reverse happens too with the 5Ghz network having issues but 2.4GHz working fine.
- Diggie3Dec 18, 2017LuminarySounds like DHCP might fail?
Can you connect a Windows PC and open a CMD window and type:
IPCONFIG /ALL
Do this when it's still working. See what your IP lease time is. Then try IPCONFIG /RELEASE * and IPCONFIG /RENEW *, then IPCONFIG /ALL again. Did your PC get a new IP address? (does it still access the internet?)
Finally wait until it loses access again and type IPCONFIG /ALL. Does it still have an IP address? Did it fail roughly when the lease expired?- spanishgringoDec 18, 2017Tutor
So far everything is working fine. I had had troubles with .12 and 14 so I flashed back to 1.0.9.6, did factory reset. Updated to 1.0.9.18 today and speeds and connectivity have been good.
- juchedDec 18, 2017ApprenticeTo add to this thread that enabling circle on this build does the same as all other versions I have tested. The internet speed tests slower and slower until eventually it is frustrating to use. Turn off circle and full speed is back. No reboot needed.
- ddurigDec 26, 2017Guide
I am having similar issues with loss of 2.4GHz. I am not running smartconnect and have seperate SSIDs with the same passwords.
About twice a day all my 2.4Ghz devices loose access to the internet. I can connect to the 5GHz via my phone and reboot the router and everything works for a few hours before I get back to the same state.
It is becoming very annoying because when I lose access my Harmony remote no longer works and it makes the wife very angry. I miss my stable firmware. I am not sure what version I was on before, but I updated via the router page and the whole thing started failing requiring a physical reboot. I upadted to 1.0.9.18 to see if it resolved the problem. Now I will have to try several older versions to get back to stable even if it means I have a security problem.
- AtoZDec 26, 2017Apprenticeddurig. They have a .20 beta version. May be worth a try. If it doesnt work, you can just go backwards then.
Thanks, I will give that a try and see. Really hoping for the stability I had.
I went 4 years without any real issues and even bypass my Google Fiber router in favor of the netgear because I have been so happy with it. I figured I should update due to Krack and that is where things went wrong. I took the web page update so figured it was stable.
