JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
MPrinter17
Dec 18, 2017Star
I disabled the smart connect and split my SSIDs. After about 30 min all the 2.4G connected devices fell off.
I disconnected my phone from the 5G network and was unable to connect to the 2.4G. I connected back to the 5G no problem. So whatever it is affects the 2.4G connections.
SeanPGH
Dec 19, 2017Aspirant
Same issue. 2g Devices unable to connect to 2g network. devices that can support both connect to 5g fine, can not connect to 2g. This is on printers, windows, android, and I havent tried apple yet. I also did another reset and for some reason it is not broadcasting the SSID any more.
