JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
HWAM
Dec 19, 2017Apprentice
mzguy wrote:
HWAM wrote:
rudiklein I know all brands can create bugs. But I am not able to repair the R7000. Even a full reset and flash the oldest firmware wasn't fixing the issue. I guess the problem firmwares broke my router.Did you try 1.0.7.10_1.2.3? It appears to be working for some time for two other users.
I tried anything. Also 1.0.7.10_1.2.3. I think my router is ruined by a recent firmware. I don't know if this is possible but I really don't understand it anymore. I work in the ICT and I can't explain this. I'm done with Netgear. I ordered a Linksys WRT1900ACS.
Volstate
I received a replacement router last Saturday after having all these same issues with dropping like everyone else. I intentionally DID NOT update the firmware when I received it to see if there were any drops in 24 hrs...there were none.
I then upgraded the router directly to the .18 firmware to test it out and in 3 days time I have had zero drops, resets, nothing. Router is running very well. I have Port forwarding on and I'm running both 2.4 GHZ & 5 GHZ together and both have the same password.
When I shipped my old router back to Netgear I used the same box that it came in when I purchased it 7 months ago. I compared the production numbers and noticed the last 3 numbers are different so I wondered if this router was produced later and possibly the earlier produced router came from a defective batch? Maybe not...I'm just brainstorming.
I also wondered if possibly the firmware that caused this initially begin somehow destroyed the router beyond repair. It's just odd I get a router with stock firmware and go directly to this firmware on a new router and I have zero issues but others with this router using the same firmware are still having the same issue. So either the routers hardware is bad from the factory or a previous firmware version has screwed the routers up. I don't see how you could draaw any other conclusion from this mess.
