JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
alexchoi
Dec 19, 2017Tutor
After update to 1.0.9.16, all my android phones lose internet connection, They still could connect to wifi thought. Wifi on computers seems working fine.
- millerman1121Dec 19, 2017Tutor
Same thing happening here Thank you all for the work and posts. Hope Netgear will have a fix soon, but might have to order a Linksys WRT1900ACS myself....
