JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
alexchoi
Dec 19, 2017Tutor
After update to 1.0.9.16, all my android phones lose internet connection, They still could connect to wifi thought. Wifi on computers seems working fine.
millerman1121
Dec 19, 2017Tutor
Same thing happening here Thank you all for the work and posts. Hope Netgear will have a fix soon, but might have to order a Linksys WRT1900ACS myself....
