JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
shamarin
Dec 19, 2017Virtuoso
Make an option to setup auto channel select for 5 GHz band, because some devices with Atheros/Qualcomm wi-fi chipsets coudn't connect with 802.11ac and drops to 802.11n speed if in router 5 GHz channel is not setup to auto select. On 2.4 GHz channel selection by default is setuped to auto select.
