JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
AtoZ
Dec 19, 2017Apprentice
Did the update about 2 hours ago. Worked immediately. Printer back up and connected. Smart home back up and communicating. Someone asked what it looks like when you are not connected. Wireless icon shows full bars, a check in Genie tells you everything looks good. Yet, nothing is communicating. When I did this upgrade, I did not factory reset. I was about to when I realized the new FW was released. But, I have had this working in the past, but then devices start falling off. I, like so many others, have no time for this. Especially if you have a business that depends on this connection. If they start to fall off again, I will have to make a decision...deal with tech support phone calls and nonsense, or go out and get another router.
- chopin70Dec 19, 2017Virtuoso
Please keep thread clean from "I am going to Linksys and such"
Personally, I left Linksys and they were, for my last 2 routers much more pain in the ass than Netgear. Since they were sold to Belkin, the quality and support dropped completely.
Just give details and let's wait Netgear fixes it
- AtoZDec 20, 2017Apprentice
Just an update. Been running about 12 hours now. Still good connection with all devices. I will continue to work all devices to see if they fail. I am currently monitoring all devices connected to the 2.4 side. I am on FW .18.
- HWAMDec 20, 2017ApprenticeYep, same for me. Yesterday I had problems. It can be stable for 24 hours but sooner or later you will get problems again.
- jimbauDec 20, 2017Aspirant
FW .18 did nothing for me. Still cannot connect to 2.4. Is there any official word from neatgear as to when a fix might be available?
