JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
shamarin
Dec 19, 2017Virtuoso
This new firmware is with serios bug. My STB couldn't boot now if i reboot it. After some period of time STB showing that "Server error. Authorisation couldn't be done". It's due to that STB couldn't get connection to ISP server (URL) that loads IPTV services and STB UI for working of IPTV and thus authorisation checks fail also too. And if IPTV services allready are booted normally VOD service is not working, if i try to play VOD video there is no stream and immideatly TV stream stops and there is no picture till i switch to another channel. With previous firmware version 1.0.9.14 it's ok. My ISP provider is Rostelecom.
