JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
AtoZ
Dec 20, 2017Apprentice
Just an update. Been running about 12 hours now. Still good connection with all devices. I will continue to work all devices to see if they fail. I am currently monitoring all devices connected to the 2.4 side. I am on FW .18.
HWAM
Yep, same for me. Yesterday I had problems. It can be stable for 24 hours but sooner or later you will get problems again.
