JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
MPrinter17
Dec 18, 2017Star
Currently running V1.0.9.18_1.2.27.
Problem is that 2.4G devices fall off the network. I've already done a Factory Reset and set everything up again by hand. After the reset or reboot, I can get everything connected just fine for about an hour or so, then the 2.4G devices fall off and can't reconnect until the router is rebooted.
I'm running Smart Connect and QoS and the R7000 is in Router mode.
brdoddsjr
Dec 20, 2017Apprentice
I have the exact same config as you. I had the same symptoms you described. This release fixed the problem for me. I'm not sure this is important, but I did power off or soft reset all my devices and let them rediscover after the update. The reason I mention this is my network discovery happened really fast and DHCP work perfectly for once. p.s. most of my devices are static or reserved IPs.
