JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
mzguy
Dec 20, 2017Apprentice
brdoddsjr wrote:Looks like this update fixed my problem. There is a known 'feature' of Android struggling to switch between wifi radios. My Nighthawk seemed to also struggle with this. I've been monitoring all morning. Steady as a rock. No drops, No T4 or T5 errors.
I've been tweaking my router for months to solve this issue. FYI: I'm not a Pro, but fairly knowledgeable. I know IP, but not hardware.
What did you do? I read the release notes, but they were a marketing consumable.
Also, my signal strength went up 14% and I haven't touched a thing.
What problem was fixed for you? Most here are posting about loss of device connectivity on the 2.4GHz radio, an issue which often doesn't show up for over 24 hours. Many, including I, have confirmed that this update did not fix the issue.
brdoddsjr
That is exactly what got fixed for me. Android has a known flaw that I believe is the root cause of my problem. The Nighthawk did help. Now it lets devices switch radios with delay. I've been working on this for months. BTW most of my devices are static or reserved IPs
