JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
jandersen
Dec 20, 2017Aspirant
I was on V1.0.7.6_1.1.99
I upgraded to V1.0.9.18_1.2.27
First halfway thought the upgrade the loading bar turned into a webpage loading error.
red ish lights flashed on the router and i could no longer open up any websites.
I waited for 5-10mins and it continued to flash.
However the blizzard messing service still worked.
I eventually reset the router afterwards speed tests results were 75ms latency .40Mbps download 1.66Mbps Upload.
When i removed the router i was able to get my normal speeds. After reading the forums i see it was a bad idea to upgrade.
I reverted back to my previous firmware and speeds returned to normal.
