JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
Diggie3
Dec 21, 2017Luminary
Are other people seeing the "DoS attack: Smurf" in the router log when the 2.4Ghz band devices drop off like mrobbeloth reported? Just wondering if there is anything in the log that points to the problem for more than one person here...
Timepilot
Dec 21, 2017Guide
No difference with F/W 18 for me. Worked for about 20hrs and then all connections dropped off - attached devices page on router showed no 2.4 or 5G connections. Going into Wireless setup page and pressing apply to restart wifi cures the issue. Tried multiple channels and all seem to have the same problem
Looks like going to have to buy a new router.
