JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
AtoZ
Dec 21, 2017Apprentice
Update to my previous posts about 18...its been about 35 hours since i downloaded and installed 18. So far everything is still connected. I havent gone this long without disconnecting for quite some time. I am waiting for disaster to strike. The problem is i havent done anything different than most of you guys. One thing i didnt do was factory reset. If the connection stays solid, i will try to help out here, if i could.
