JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
aabshire
Dec 21, 2017Apprentice
Not at total fix but I have disabled 5 ghz, turned off QoS and have not had any issues for 2 days now. At least I am working partially
millerman1121
Dec 21, 2017Tutor
Same here. Turned off 5gHz and qos and no drops for past 30 hours .
