JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
rudiklein
Dec 21, 2017Star
In case someone missed this post (sounds promising):
rudiklein
Dec 21, 2017Star
So the previous post could be a winner, or as mentioned in another post:
Switch off 5Ghz and QoS and 2.4Ghz is stable again.
(I won't bet you a case of beer on these solutions, but what the heck, give it a try).
Even better: do the actions in the previous post, switch off 5Ghz and QoS, pray to the god of your liking, switch on all the lights in you house, disconnect the dishwasher......and then see what happens.
