JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
rvcjew
Dec 22, 2017Tutor
I don't use my 2.4ghz much except for game consoles but this has been happening to my network for months now on the 5ghz band. And It also keeps dropping one of our printers (wired Brother) as well. wake up or suddenly lose internet while using it on wifi devices and tunr wifi on and off on devices then they can no longer get an ip even though they are set static. I do use ACL and at times the guest network also does not work as people get thrown in the ACL odd. Firmware is V1.0.9.14_1.2.25
EDIT: I repair networks and pc's as my job so I recomend this router personaly a lot if they need the features it provides and I have much experience with it and now this can no longer be a thing if NETGEAR does not come clean and explain what they have been doing to address this and what is even changed in the change logs vs just saying fix's.
AtoZ
Dec 22, 2017Apprentice
Same here. I have installed them and recommended netgear to clients and family. Im not feeling the love right now. I did get the system stable for the last 48 hours or so, but speed is sketchy. I am currently adjusting settings to see if i can get a bit faster.
