JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
Retired_Member
Dec 22, 2017Seems my posts keep disappearing... Please disable the IPv6 status output via console. It spams the serial console while I'm trying to do work.
[85164.750000] connection 1397 change state to closing. [85164.820000] connection 1442 change state to closing. [85164.850000] connection 1393 change state to closing. [85164.940000] connection 126 change state to closing. [85165.080000] connection 8 change state to closing. [85165.120000] connection 1407 change state to closing. [85165.160000] connection 1455 change state to closing. [85165.550000] connection 1484 change state to closing. [85165.580000] connection 960 change state to closing. [85165.610000] connection 132 change state to closing. [85166.280000] connection 1515 change state to closing. [85166.480000] connection 1512 change state to closing. [85166.750000] connection 1537 change state to closing. [85167.190000] connection 1540 change state to closing.
- brdoddsjrDec 22, 2017Apprentice
Seems I have joined the ranks of the 2.4G disturbed. All my 2.4G devices simply disappeared from the connected device's screen, so I assume the router tables also. Nothing to tell what went wrong. no errors. no log messages. A simple reboot fixed the problem. Last time I thought it was related to renewing my lease. Not the case this time. Also checked my modem logs. The ISP side was stable when this happened.
- HWAMDec 22, 2017ApprenticeI hope the Netgear engineers are really panicking now. This will involve more and more people. What a terrible end of the year for the one who made a big mistake. They don't even answer my support case anymore.
- rvcjewDec 22, 2017Tutor
They may all be gone for the holidays now. Perhaps will get some love in January.
