JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
Ouin
Dec 22, 2017Tutor
Somebody already try this beta release V1.0.9.20_1.2.28 ?
Hoyty
Dec 22, 2017Apprentice
Ok, so it is a BETA but oddly released. It was built 12/17/2017 (previous .18 was built 12/7/2017). I will install to see what happens, but I am not having any issues so I am not best test probably.
- Diggie3Dec 22, 2017LuminaryI don't know why they don't just diff the code from the working release to the broken one. How hard can it be to see what changed? I do this all the time on my own projects.
- juchedDec 22, 2017ApprenticeIf someone installs 1.0.9.20, could you post the Disney Circle version included inside? The last one was 2.0.7.8.
Thanks.
