JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
IrvSp
Dec 23, 2017Master
I have this f/w installed and have hit a problem.
It is with the DLNA server on READYSHARE.
It is with my iPad. I have a variety of programs on it (iOS 11.2.1) that access the network and work with a DLNA server. ACEPlayer (https://itunes.apple.com/us/app/aceplayer-plus/id480962404?mt=8) is one of them. When I access the R7000 which it sees, I select Media Explorer, R7000, Browse Folders, and it is EMPTY! It used to show me folders and I could open that and select a file to play. I tried a few DLNA players with the same results.
This USED to work fine, last used a few weeks ago. Complicating all this is that 3 things have happened probably after I last used it:
- iOS was updated to 11.2.1
- Netgear F/W updated
- ACEPlayer updated
Oh, I used NETGEAR GENIE to open READYSHARE and it works and sees the files?
I have searched the web looking for complaints that DLNA doesn't work on iPad's... can't find anything?
At a loss why Genie would work (it seems to d/l the file before playing it)?
Right now, I'm going to wait for awhile before doing anything, and assume someone here will verify if it is indeed the f/w or not. Don't see a reply on this, I'll look into the Beta .20 or go back to .18 that did work...
- IrvSpDec 23, 2017Master
UPDATE:
Discovered that the SAMBA server still works in programs that support it. Suspect Genie app is not using DLNA but SAMBA to read the files.
- VolstateDec 23, 2017Apprentice
Since Netgear replaced my router I have had zero disconnects. I'm running the .18 firmware. This tells me that either Netgear put out defective units (because the production number I received is later than the one that was resetting) or some of the firmware that put out in the past messed up the units somehow (because the only firmware I have upgraded to since receiving the router is .18). So while my unit is staying stable running the latest firmware as everyone else others are reporting constant resets. Something is not right with that....
More info and debug on my DLNA problem...
I tried to look at the R7000 on the network using Windows Explorer on my wired PC. Not there? I user NET VIEW, not there? Really odd... So I entered NET VIEW \\192.168.1.1 and it showed the shares?
Perplexed I decided to REBOOT the R7000.
Surprise, PC Windows Explorer and NET VIEW see the R7000. So does ACE PLAYER see the folders and can play the video files.
This has NEVER happened to me before... something has to be wrong here. It can't be due to a power drop either. My Modem and R7000 are on a UPS.
- IrvSpDec 24, 2017Master
Problem continues. This morning I booted my wired PC. Checked with Windows Explorer the NETWORK. R7000 did NOT show again! Did a NET VIEW and got these results:
C:\>net view
System error 1231 has occurred.
The network location cannot be reached. For information about network troublesho
oting, see Windows Help.
C:\>net view \\192.168.1.1
Shared resources at \\192.168.1.1
readyshare
Share name Type Used as Comment
Movies Disk read:all-no password;write:all-no password
USB_Storage Disk read:admin;write:admin
The command completed successfully.=========================
That first error is kind of strange. Web searches for it did not help... Why did NET VIEW work when I used the IP Address?
To RULE out W10 as a problem, I just rebooted the R7000 and NOT W10 which is what I did yesterday. Now everything worked?
C:\>net view
Server Name Remark
\\READYSHARE readyshare
readyshare
C:\>net view \\readyshare
Shared resources at \\readyshare
readyshare
I'm pretty sure now this is an R7000 flash problem.
